1 - 2 of 2 Posts
found an oil spot where bike was parked.
engine is clean so could not understand ...
Finally found the oil dropping from the setting screw of the RH fork tube (non-inverted fork on 2003 R6) :(
Also found that the screw setting was probably opened too much but I fear the seal inside (if there is one :confused:) is bad.
Problem, nowhere in spare part catalogs or shop manual I can find any data about this compression damping screw and repair.
How to deal with that ?
thx !
Discussion Starter · #2 ·
No one seen that ?
I talked to Yamaha God mechanic, he said he never saw a leak here ... :werd
I set back to standard setting and it is not leaking anymore in static. But what will happen when driving :cuss
1 - 2 of 2 Posts
