1 - 20 of 20 Posts
Well i need some help with engine code 12. some history. i droped my bike and the crank case was broken, oil spilt out, bought the part again raplace everything. and now i try to turn on the the bike and it just wont. could i have mess up something else. i reseached and there was a very similar case to mine of a member and all he did was recharge the battery. just took it to the dealer to be recharged. the bike cranks when i press the switch but it just wont turn on. and the check engine light flashes and then it gives the code. any input on this matter.
thank you
I found this, it is from the FZ6, which is pretty much a naked cheaper version of the R6.... Hope it helps. Makes sense.......
Here are the Definition of the Fault Codes listed in the FZ6 Service Manual:
Fault Code: 12
Diagnostic Code: --
Symptom: No normal signals are received from the crankshaft position sensor.
Probable cause of malfunction:
Open or short circuit in wiring harness.
Defective crankshaft position sensor.
Malfunction in pickup rotor.
Malfunction in ECU.
Improperly installed sensor.
Fault Code: 13
Diagnostic Code: 03
Symptom: Intake air pressure sensor-open or short circuit detected.
Open or short circuit in wiring sub lead.
Defective intake air pressure sensor.
Malfunction in ECU.
Fault Code: 14
Diagnostic Code: 03
Symptom: Faulty intake air pressure sensor pipe system
detected hose
clogged hose
Intake air pressure sensor hose is detached, clogged,
kinked, or pinched.
Malfunction in ECU.
Fault Code: 15
Diagnostic Code: 01
Symptom: Throttle position sensor-open or short circuit detected.
Defective throttle position sensor.
Malfunction in ECU.
Improperly installed throttle position sensor.
Fault Code: 16
Diagnostic Code: 01
Symptom: A stuck throttle position sensor is detected.
Stuck throttle position sensor.
Malfunction in ECU. 01
Fault Code: 19
Diagnostic Code: 20
Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
Open circuit in wiring harness (ECU coupler).
Malfunction in ECU.
Fault Code: 21
Diagnostic Code: 06
Symptom: Coolant temperature sensor-open or short circuit detected.
Defective coolant temperature sensor.
Malfunction in ECU.
Fault Code: 22
Diagnostic Code: 05
Symptom: Intake air temperature sensor-open or short circuit detected.
Defective intake temperature sensor.
Malfunction in ECU.
Fault Code: 30
Diagnostic Code: 08
Symptom: The motorcycle has overturned.
Overturned.
Malfunction in ECU.
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Fault Code: 34
Diagnostic Code: 31
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
Malfunction in ECU.
Fault Code: 41
Diagnostic Code: 08
Symptom: Lean angle cut-off switch-open or short circuit detected.
Defective lean angle cut-off switch.
Malfunction in ECU.
Fault Code: 42
Diagnostic Code: 07, 21
Symptom: No normal signals are received from the speed sensor; or, an open or
short circuit is detected in the neutral switch.
Defective speed sensor.
Malfunction in vehicle speed sensor detected unit.
Defective neutral switch.
Malfunction in the engine side of the neutral switch.
Malfunction in ECU.
Fault Code: 43
Diagnostic Code: 09
Symptom: Supply power to the injector and fuel pump is not normal
Open circuit in wiring harness. (red/blue line or blue/yellow line)
Malfunction in ECU.
Fault Code: 44
Diagnostic Code: 60
Symptom: An error is detected while reading or writing on EEPROM.
Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
Fault Code: 46
Diagnostic Code: --
Symptom: Power supply to the FI system is not normal.
Malfunction in "CHARGING SYSTEM".
Fault code: 50
Diagnostic Code: --
Symptom: Faulty ECU memory. When this malfunction is detected, the code
number might not appear on the meter.
Malfunction in ECU. (The program and data are not
properly written on or read from the internal memory.)
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Malfunction in meter.
Malfunction in ECU.
Fault code: Er-2
Diagnostic Code: --
Symptom: No signals are received from the ECU within the specified duration.
Improper connection in wiring sub lead.
Malfunction in ECU.
Fault code: Er-3
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Malfunction in ECU.
Fault code: Er-4
Diagnostic Code: --
Symptom: Non-registered data has been received from the meter.
Malfunction in ECU.
Discussion Starter #3
i think that am gonna go with this. if the baterry works is chaged and still doesnt work then i will replace this sensor. but what alse can it be becuase the sensor looks fine.
Discussion Starter #4
^^^^i ment i will go with this forgot to post
Fault Code: 12
Diagnostic Code: --
Malfunction in ECU.
I would make sure all the plugs are on good, and all wires are not damaged. I am not sure if you can get to the sensor without tearing the motor down, that would suck.... Hope you get it figured out...
Discussion Starter #6
the sensor if am right its located inside the right side crank case and now that i recall it look a bit damage. but i dont know. i have to see if the battery works.
Discussion Starter #10
thanks a lot bro. well i also want to get an 08. its sad that u dont live close to me otherwise i would let u take my bike for a ride its awsome, but get and 08 u wont regret it.
Discussion Starter #12
I live in SoCal am always looking for people to hang around with but most people that i talk to seem to be jerks. so i guess am looking for people with bike to hang around.
Discussion Starter #14
its always nice to meet new people who share same interest, so when u happen to pass by socal let me know so we can kick it.
what part of SoCal are you in?
Also, your initial description is a little vague. Which side cover did you break? If you broke the side cover with the crankshaft pickup sensor, theres a few things that could have gone wrong when you replaced it. If you didn't transfer over the sensor correctly to the new one, it won't pick up the signal. It is possible (but difficult) to install that sensor backwards. Also, when you remove that cover, there is a 3 inch metal dowel that holds a cam chain guide in place, if that dowel comes out of the motor, you run a high chance of having your timing chain skip a tooth, meaning that all of your timing is off and when you try to start it, you could have bent the valves.
Discussion Starter #16
u right that is the side i screw up and the dowel it came of when i took out the case. but i dont think timin was skiped i will recheck the timing. i will order the sensor later this week. and i will repalce it. it seems u know about this so can i mail u is i cant seemto fix it. by the way am in anaheim. thanks
I only know about that, because I just replaced that cover and got a call from my suspension shop today saying my timing was off a tooth. I tried to be careful when I did it, but I guess it still jumped a tooth. I got lucky because no one had tried to start the bike yet, so I didn't bend/break anything.
I was just down in anaheim today getting my frame welded. Tore a nice little chunk out of it. If the new sensor doesn't work, just post back up in here or send a pm, i stalk the forums regularly
Discussion Starter #18
thanks a lot bro. i'll order the sensor this weekend. and it takes 4-10 days to arrive so i will be without my bike for another two or three weeks.
hi,i m new here...
2008 r6(stock):(,malaysia,
i have question about "engine trouble warning light"....when i go at 10k rpm(170km/j) about 20km....my engine trouble warning light is on...but it not display the 2 digit error code?....pls help....
1 - 20 of 20 Posts
