1 - 3 of 3 Posts
My 03 yzf r6 had been sitting in the garage for the last 2 months until last week when some one came and test drove it. Started up fine and this guy takes it for a ride, 2 minutes latter he calls saying the bike won't turn on. Pushed it home and hasn't started sense. The check engine lights on. When I turn the key to on all it shows on the "dash" is an "11" I bought a new battery, all fuses are good. Any idea of what can it be? Help... Thanx!!!
nova r6
http://www.r6messagenet.com/forums/...254-r6-service-maintenance-repair-manual.html
Link to the service manual
Go to chapter 7 that's where the fault codes are located.
Code 11 Cylinder identification sensor
No normal signals are received from the cylinder identification sensor when the engine is started or while the motor cycle travels.
NOTE:
This code appears if no normal signals from the start switch is turned ON.
1 - 3 of 3 Posts
