1 - 3 of 3 Posts
Seems like a gauge issue but the rpm needle only red lines at high revs in neutral. Tested it today and hit 80 in 4th and the bike was screaming but the rpm gauge And speedometer were barely moving. Actually happened in all gears through 4th Any ideas what could cause this? Chalk it up as noob user error?
What do you have done to your bike? Do you have an ecu flash or anything?
not that I'm aware of, will check when i get home. If there is, could I remove it and have the bike re-tuned?
EDIT: come to think of it when i removed the seat the other day i didn't see one
1 - 3 of 3 Posts
