1 - 9 of 9 Posts
‘04 R6. When I start the bike it screams! I have adjusted the Diag code (01) to 15, 13, 12, 8, etc., and the issues stands. I purchased a new TPS and the issue still stands. Please help!!!
Did you recently change your ecu? I changed my ecu, but it was for a r6r, when the bike starts it would Rev by itself for a few Seconds then stop. Like Rev up to like 5-6 rpm for like 10 Seconds. I changed to the correct ecu and got rid of the problem
Sent from my SM-G965U1 using Tapatalk
Discussion Starter #3
I have not changed the exu
[/QUOT
Completely back-off the throttle plate screw, so the throttle plates are closed. (look at where the screw meets the stop, NOT at the throttle plates) Adjust auto choke screw for a ~2,000 RPM cold idle, and after warm-up, use the throttle plate stop screw to adjust idle back to ~1,400 RPM. Auto choke cylinder and the sliding assemblies may need to be cleaned up prior. Also, it relies on cooling system pressure... so a leaky thermostat, low coolant, air the system or bad radiator cap will contribute to malfunction.
By the way, when you post codes, tell us what they mean. Whatever all those nine-hundred and ninety-nine codes are, are the likely clue to the issue. I just get tired of looking them up. Please do that first and post their meaning, before following the instructions I posted above. Otherwise you'll potentially make things worse.
Discussion Starter #7
I really appreciate the feedback. The diag code I am referring to d01 is for the TPS. I set it to 18, but still did not see a change. Sorry for not specifying the code when I submitted my posted. The only fault code I have now is 22, which is a “failure temperature sensor in the inlet/error in the inlet temperature sensor”, which I believe it is just not connected properly versus being broken, but I will check on it. My battery is practically dead at this point, as the engine will not turn over. My multimeter shows 11.5v, so now I am waiting a 5amp charger to arrive in the mail. Once I get the battery situation figured out I will try your suggested efforts with the throttle plate screw. Thank you again for the advice.
If the battery is old, might be time to replace. After recharging: If the battery can't maintain proper standby voltage, or can't maintain just north of 10v (<-- memory serving) while cranking, time to replace. Running on a bad battery is hard on the charging system, and can contribute to premature failure. The fact that they do a lot of sitting, leading owners toward running on discharged and bad batteries, I suspect is why motorcycle charging systems, see a lot of failures. Batteries can also fail in a way in which, it's just low capacity. So they'll output well, maintain proper voltage, but be worthless after only a couple of minutes of running the engine fan.
So the TPS is now within minimum and maximum parameters? It will smoothly increase from minimum to max and its min/max is consistent whether hot or cold? When the intake temp sense isn't present, the ECU assumes a constant air temp of 68°F. In open loop (cold engine) I'm not sure whether the ECU uses this data until coolant temp reaches 104°F (closed loop, warm engine). But it has to be fixed anyway.
Once you've eliminated all the codes, see about cleaning up then adjusting the auto choke per prior instructions/information. Often a bunch of crud develops around that tiny piston. The sliding-assembly sometimes needs a tid-bit of TLC also.
Discussion Starter #9
This worked! Thank you. I was able to locate the throttle plate screw and back it off to get it calmed down. I was amazed. I won't tell you how the screw got to where it was as this is pretty embarrassing, but I am good now. I will adjust the RPMs as mentioned above. Just hearing it run normally feels great. Thanks again.
1 - 9 of 9 Posts
