Vendor
A new color from HJC in their popular RPHA-10 lineup, the Halcyon, is now available from Riders Discount!
The shell of the RPHA-10 is an advanced composite that combines carbon fiber, fiberglass epoxy, aramid epoxy and organic fibers in a precisely aligned weave that excels in strength, energy absorption and weight savings. HJC calls this their Performance Integrated Matrix (P.I.M.) construction and it saves weight by reducing unnecessary overlap and resin build-up. The PIM shell is not only strong and light, but it is also aerodynamic and quiet thanks to extensive CAD design and wind-tunnel testing.
A hot helmet is an uncomfortable helmet, so HJC made sure that the RPHA-10 is able to keep your head cool and comfortable in warm weather. Ventilation comes from two large intakes on the top of the head, and one on the chin. All three are highly adjustable to allow for variable amounts of airflow depending on the conditions. These vents move a lot of air through the helmet without the higher noise levels that can come from some ventilation systems. Inside the shell, the full-removable/washable SilverCool liner helps wick away moisture and features a Gingko extract coating for a natural anti-bacterial guard.
All RPHA-10 helmets come with HJC’s newest HJ-20 Pinlock shield and insert for the best in fog prevention. These shields also feature an easy to use center locking mechanism that prevents the shield from accidentally popping open if you turn your head to look behind you or to the sides.
If you’re interested any of the RPHA-10 graphics, or another HJC helmet, you can get in touch with Brad for expert sizing advice and more information. Feel free to send him a message through this forum or give him a call at 866.931.6644 ext. 810. You can also send an email to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away!
