1 - 13 of 13 Posts
Vendor
When we first saw this helmet, it elicited a couple of laughs around RD Towers. But the green grew on us and the overall look is perfect for anyone that wants a bright helmet for high-contrast visibility on the road. We’re sure the kids in the car next to you at lights will get a kick out of it, too.
The RPHA 11 Pro gives you everything you need for a safe, comfortable ride wherever you go. This helmet was engineered from the cheekpads up to be a premier lid worthy of use on some of the world’s fastest riders.
A reinforced carbon and carbon-glass hybrid fiber shell provides the shape of the helmet in which your head is protected from all angles. It’s light, strong and designed to disperse impact energy over larger area so less energy is transferred to the user. Directly below this is an ergonomically-shaped EPS liner that’s covered on the rider’s side by a fully-removable Multicool interior liner. This liner is treated in a way that does two things; first, it pulls moisture away from the body, keeping you cool and dry. Secondly, you have to deal with all of that moisture somehow, and you don’t want it to be a nice home for bacteria to grow. To look after the smell that comes with bacteria, the liner is treated with a material that prevents microbes from stinking up the liner.
Outside of the helmet, you’ll find one of the easiest visor changing mechanisms we’ve ever encountered. It takes literally five seconds to change shields. If you can ride bikes, you can change this shield, easily. At the front of shield, there’s a push button tab that locks the visor down securely at all speeds. It allows you to easily crack the visor as well, for a little extra cooling capacity when you need. And best of all, every helmet ships with both, a clear visor and a smoke shield in the box. There’s no need to add that item to your order!
Outside of the shell, HJC engineers fitted a range of intakes and exhaust ports to move air over the skull while you ride. Check and forward-facing intakes can all be adjusted easily with a gloved hand. And for the cool-weather rider, a removable chin skirt is also included with the RPHA 11 Pro helmet. It’s a really nice touch that allows you to stay comfortable in a wide range of riding conditions.
Available in a range of sizes, give TJ a call for exceptional sizing guidance and lightning fast shipping. 866.931.6644 ext 817 is the number. You can also send a note to [email protected] with HJC RPHA 11 MONSTERS INC Helmet in the subject line, post up below or PM us right here and we’ll get you dialed in.
Vendor
Discussion Starter #5
The tech guys are in the process of rebuilding the backend of the website so there is a good chance the brand isn't currently visible. We have a good selection of the product on the shelf, so if there is something you would like to order just let us know.
Love love love the HJC RPHA 11!!
On my second one already, I had to replace my original Venom graphic one and now I'm on the Kylo Ren one. For sure will have to add this to the wish list for later :)
1 - 13 of 13 Posts
