1 - 20 of 20 Posts
Squid Killin' Pirate
GoPro HD Motorsports Hero Camera - $239.69 - Free Shipping
Click here: Ho Ho GoPro Sale
Product Specs:
PC/MAC/TV/HDTV Compatible
· 1 HD HERO Camera (5 megapixel)
· 1 Rechargable 1100 mAh Lithium-Ion Battery
· 1 Waterproof Quick-Release Housing (180’/60 m)
· 3 Flat, 3M™ Adhesive Mounts
· 2 Curved, 3M™ Adhesive Mounts
· 2 Quick-Release Buckles
· 1 Vertical Surface “J-Hook” Buckle
· 1 Suction Cup Mount
· 1 Three-Way Pivoting Side Arm Assembly
· 1 USB Cable
· 1 Component Video (HDTV) Cable
· 1 Composite Video + Audio Out Cable
· Warranty: One Year
Tech Specs:
Camera Optics
Lens Type: Fixed Focus (2ft/.6m – ∞), glass
Aperture: f/2.8 (high performance in low-light situations)
Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
Angle of View: 127º wide angle in 1080p mode
Video
HD Video Resolution Modes: (subject to change, pending final firmware release)
1080p = 1920x1080 pixels (16:9), 30 fps, 15 Mbit/s data rate
960p = 1280x960 pixels (4:3), 30 fps, 12 Mbit/s data rate
720p = 1280x720 pixels (16:9), 60 fps, 15 Mbit/s data rate
720p = 1280x720 pixels (16:9), 30 fps, 8 Mbit/s data rate
WVGA = 848x480 pixels (16:9), 60 fps, 8 Mbit/s data rate
Sensor Type: 1/2.5" HD CMOS, 2.2µm-sized pixels
Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
Exposure Control: Auto with user selectable center weighted average and spot metering settings
White Balance: Auto
Audio
Microphone: Built-in, mono with AGC (automatic gain control)
Audio Format: 48 kHz, AAC audio compression
Resolution: 5 megapixel
Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Storage
Memory: SD card, up to 32GB capacity (SDHC)
Average recording times (using 32GB SD card):
1080p (30 fps): 4h 21m
960p (30 fps): 5h 26m
720p (60 fps): 4h 21
720p (30 fps): 8h 09m
WVGA (60 fps): 8h 09m
Camera Connectors & Cables
PC Connection: USB 2.0 (data connection and battery charging)
HDTV Out: HD NTSC & PAL (component cable incl.)
Audio Out: Combo 2.5mm jack with stereo audio and composite video out
PC Compatibility: Windows® XP (Service Pack 2 or later) or Vista; Mac OS® X 10.4.11 and later
Power & Battery
Battery Type: Rechargeable 1100 mAh lithium-ion
Battery Life: Approx. 2.5 hrs
Charging: via USB to computer or optional power adapter
Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
Waterproof Camera Housing
Depth Rating: Up to 180 feet / 60 meters
Construction: Polycarbonate and stainless steel
Hardware: Stainless steel
Size & Weight
Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
_________________________________________________________________
PM me if you have any questions!
Moderator Narcissist
Damn... *snap* Missed the fun!
Brit, I'ma hit you up after the turn of the year for some stuff! In the mean time... :popcorn:
track junkie
how bout the 960HD. any deals on it.
I'm thinking bout one of those sice I don't have an HD tv anyway and they only retail at 179 If I remember correctly.
960 - $143.99 w/ free shipping
Wide angle - 159.20 w/free shipping
GoPro® HD HERO 960 features the same professional grade 960p, 720p and 480p (WVGA) video & 5MP timelapse photo modes, and incredible sound recording system as its big brother, the original HD HERO camera.
Missing from the HD HERO 960 are 720p @ 60fps, 1080p video, and the HERO BUS expansion port in the rear of the camera that will let you take advantage of GoPro's forthcoming BacPac accessories - LCD screen & Battery Extension - both important features for filmmaking hobbyists & professional videographers that are compatible with the original HD HERO camera.
What's Included:
* 1 HD HERO 960 camera
* 1 Rechargeable 1100 mAh Lithium-Ion Battery
* 1 Waterproof Quick-Release Housing (180' / 60m)
* 1 Curved, 3M™ Adhesive Mount
* 1 Flat, 3M™ Adhesive Mount
* 1 Helmet Front Mount
* 1 Headlamp-Style Head Strap
* 1 Quick-Release Buckle
* 1 USB Cable
* 1 Component Video Cable (HDTV)
* 1 Composite Video Cable + Audio Out Cable
* Warranty: One Year
$143.99 w/free shipping
Tech Specs:
Camera Optics
* Lens Type: Fixed Focus (2ft/.6m – ∞), glass
* Aperture: f/2.8 (high performance in low-light situations)
* Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
Video
* HD Video Resolution Modes: (subject to change, pending final firmware release)
* Sensor Type: 1/2.5" HD CMOS, 2.2µm-sized pixels
* Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
* Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
* Exposure Control: Auto with user selectable center weighted average and spot metering settings
* White Balance: Auto
Audio
* Microphone: Built-in, mono with AGC (automatic gain control)
* Audio Format: 48 kHz, AAC audio compression
* Resolution: 5 megapixel
* Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Storage
* Memory: SD card, up to 32GB capacity (SDHC)
* Average recording times (using 32GB SD card):
* PC Connection: USB 2.0 (data connection and battery charging)
* HDTV Out: HD NTSC & PAL (component cable incl.)
* Audio Out: Combo 2.5mm jack with stereo audio and composite video out
* PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.4.11 and later
Power & Battery
* Battery Type: Rechargeable 1100 mAh lithium-ion
* Battery Life: Approx. 2.5 hrs
* Charging: via USB to computer or optional power adapter
* Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
* Depth Rating: Up to 180 feet / 60 meters
* Construction: Polycarbonate and stainless steel
* Hardware: Stainless steel
Size & Weight
* Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
* Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
OMRRA #79
I will be sending my wife your way to get me one of these for X-mas..............now to figure out how to tell her what I want and where to get it without her knowing I am "telling" her what I want AND where to get it!:lmao
Discussion Starter · #15 ·
I appreciate it when my man tells me what he wants and where to get it... it makes my life easier.
Send her an email with a link and write: "Look how cool this is! I might have to ask Santa for one of these."
Good luck!
1 - 20 of 20 Posts
