1 - 5 of 5 Posts
I first noticed a couple days ago took some cleaner and got rid of it..so obv its leaking :nono ..well now its back.. there like a puddle formation in the crack too. oil level is still good... can I ride it or should I wait till tues the earliest I can get it looked at? dammit
thanks for any help
Discussion Starter · #2 ·
:popcorn:
My R6 eats Chuck Norris
Correct me if I'm wrong.
This is just a plug with a rubber "o" ring, right?
Replace the "o" ring and make sure there are no burrs or cracks, good to go?
Unless the ring is fine and it's a pressure issue pushing oil out?
easy to do. drain the oil. remove the plug (take a big screwdriver and wrap the end w/ a few layers of electrical tape). inspect/clean sealing surfaces. order a new o-ring, if necessary. re-torque to proper value.
NVM. just take it. im sure they have a tool that's used to remove/install it
cool..but i'm lazy so its going back to the dealership..that should be covered under warranty
1 - 5 of 5 Posts
