... take the headlight glass off of the headlight housing? I see the little tabs, about five, around it, pulled them all up, and the lens won't budge. There's 3 screws on each side in the back of the headlight assembly..., they just spin and spin.
I need to get in there to mount the blinkers. It's an 04..., thanks for the help.
Have you finished it yet? How did it turn out? Oh, and why do you need to remove the clear lens? I would think you could just drill through the back of the housing and put the signals in that way. That's what I did.
Or instead of drilling, to prevent shavings from getting into the housing, you can heat up the end of a copper tube and melt through it. Be sure to use the right diameter.
