1 - 20 of 101 Posts
Two Bro's=ORGASM *nohomo*
Requirements:
- 05 R6 or 06-09 R6S
- POWER COMMANDER! with a special map for use with slide stops (or I suppose if you're using AutoTune it'll do it for ya)!!
These two maps were available from Graves at some point in the past (RIGHT CLICK, SAVE TARGET AS):
GRAVES.R6.03.P.SS.PR.ST - Full Graves Exhaust + Graves Slide Stop Kit
and
GRAVES.R6.03.P.SS.PR !!RACE USE ONLY!! Full Graves Exhaust, Graves Slide Stop Kit
*Note: If your bike has a rough idle after loading either of the above maps, adjust the 0% column from 0 RPM to 2250 RPM with a different number until your idle is smooth.
- Slide Stop Install Instructions! Also archived HERE in case that link dies.
Apparently this won't work on 03 and 04 R6's because they have a low fuel pressure problem on the fuel rail when you do this. Graves sells a fuel pressure booster (looks a like a washer? lol) that apparently fixes the problem.
Graves wants $75 for their 4 pieces of aluminum pipe (in case anyone wants to make it out of aluminum pipe, 1.5" NPS SCH 30 x 38mm long is what Graves uses) and after reading the Turbo R6 project thread I decided I'd make some slide stops myself! I mean if they're holding up on that crazy beast, they'll damn sure hold up on mine!
Supplies:
4 x 1.25" CPVC Couplings (*NOTE: "common" PVC is not gasoline recommended):
LICK FOR HIGH RES!
Tools:
- Something that can measure length ACCURATELY, micrometer, etc.
- A saw, preferably one that can cut straight (to cut the couplings down to 39/38mm in length).
- Dremmel or file or be creative (to remove part of the "lip" inside the couplings).
- Phillips #2 screw driver BIT (to have fun removing the screws from the slide caps!)
- A bench grinder works great for beveling the edges but I guess that's optional.
Instructions:
Ok, to make the slide stops it's pretty damn easy. If you're going to bevel the edges I would cut the couplings down to 39mm, if not cut it down to 38mm.
LICK FOR HIGH RES!
After you've cut them to the desierd length you need to remove part of the lip that's inside the coupling. Make sure you get rid of it right flush to the wall of the coupling. The slide rail is a super tight fit so if you leave any material there, it wont. You need to remove two chunks (opposite eachother) or you can remove the whole damn ring if you want.
LICK FOR HIGH RES!
Now you can do a test fit of the stock slide rail! You want to make sure that it goes all the way in, until the coupling is hard against the rubber boot base (and totally flush/level!).
LICK FOR HIGH RES!
If the coupling snugs right up against the boot base then go ahead and bevel the edges (if you cut your coupling to 39mm). The reason why I beveled the edges is two fold. 1, it allows the coupling to sit perfectly flush against the slide stop housing, and 2, it allows the boot to sit naturally instead of bending itself over the edge of the coupling and throwing off the length of the boot and the alignment when you try and put it back in the throttle body!
LICK FOR HIGH RES!
Repeat the process three more times so you have four in total.
LICK FOR HIGH RES!
Now you can install them back in the throttle body! Make sure the coupling is tight against the boot base before inserting it into the throttle body. MAKE SURE TO PUT THE SPRING BACK IN WHEN YOU REASSEMBLE IT!
Remember, the SHORTER your slide stop is the more the slide protrudes into the throttle body opening. The longer the slide stop is the more tucked away the slide will be.
I'm a bit of a perfectionist so I wanted my slides to be totally flush with the throttle body wall, not tucked in, not protruding. I used my grinder and took little bit by little bit off my 39mm completed units until the slide was 100% flush with the throttle body wall :)
LICK FOR HIGH RES!
Here is a pic BEFORE the slide stops are installed (the way the bike comes from the factory):
LICK FOR HIGH RES!
And here is what it should look like if you've done everything correctly :)
LICK FOR HIGH RES!
She idles a little lower than before, about 150rpm less, has a super nice deep growl at idle, AND when you roll on it! YOUTUBE VID!! If you've got good speakers and/or a subwoofer crank it up!
LICK FOR YOUTUBE VID!!
I think that's it!?
Twist it and rip it!
-Jamie M.
BAUCE Racing Co-Founder
Re: $4 DIY Slide Stops! 05 R6 & 06-09 R6S! Improve throttle response&better accellera
Awesome! Thanks for the info. I'm gonna look into this booster (washer) thing for my 03 and give it a whirl! Good lookin out man!
Parts Pimp
Personally I'd drop the $40 on the set from Graves bro. And I bet if you call tobefast and talk to Shane you could get an even cheaper price.
I'm not too sure how well PVC will hold up against contact with fuel. There will be some spray that gets on them here and there. It's unavoidable.
http://www.tobefast.com/graves-r6-slide-stop-kit-pr-235.html
^true about the fuel. op let us know how this holds up for you!
Discussion Starter #5
I asked the plumbing guy I bought the fittings from and he pulled a book out from his supplier, it said CPVC (what the fittings are made out of) is 100% gasoline (and additives, Toluene, etc.) compatible . It also said "common PVC" is not gasoline recommended.
-Jamie M.
Discussion Starter #6
The guy in the turbo R6 thread has been running them for three years without issues, and he's coated them with fuel and oil many times from his turbo misadventures and he says his slides are still 100% where they were when he built it :)
-Jamie M.
Yeah thats def Important info mang! You know someone will **** that up if you don't go back and edit that into your op. Make sure you specify the CPVC part!!!
Parts Pimp
-Jamie M.
-Jamie M.
Awesome info!
But will your dremelled out pvc pipes flow as well as the graves ones which are probably CNC machined, or at least completely smooth on the inside where the air flows.. Dremelling out that lip isn't gonna leave you a perfectly smooth finish. It'll disrupt the air and cause turbulence.
If I'm putting a part on my bike that gives me a couple horses, I'm not tryin to jeapordize those 2 horses over $36 or so! I'm just sayin!!
Discussion Starter #9
Done and done. The reason why I didn't think it was important was because the plumbing guy said all of the fittings were CPVC, PVC is just used in pipe. But, he may have been talking about just his store, or it could be different in the US, etc.
-Jamie M.
Discussion Starter #10
No air flows through the coupling or inner boot area, it's sealed. If you built it out of popsicle sticks it would perform identical to the graves tubes ;)
-Jamie M.
Parts Pimp
-Jamie M.
:dunce:
I don't know why, but I was thinking they go where the velocity stacks mount. :lmao
Discussion Starter #12 (Edited)
LOL! Nice! :) You'd think the way Graves anodizes them and makes em all pretty they would go somewhere someone might actually see them, but nope, they are packed inside those black domes in this pic:
LICK FOR HIGH RES!
**Edit: I've gotten quite a few PM's about "what did it look like before" and I just noticed I had taken a good pic before the mod. This is what it looks like normally:
LICK FOR HIGH RES!
-Jamie M.
Kick ass! Even if I get the commercially made ones, I still may makes these...and I have sick access to aluminum and a full machine shop :sing
Discussion Starter #14
Nice! I tried EVERYWHERE to find Sch 30 aluminum pipe and every place I went said it was special order, 2 weeks delivery, and I had to order EIGHT FEET! lol. If you got access to a lathe take some 1.5" NPS pipe (actual O.D. is 1.900") and machine out the inside until it's 1.654 and you're ready to rock! Cut a bunch at 38mm and sell em for $40 :)
-Jamie M.
Discussion Starter #15 (Edited)
-Jamie M.
Discussion Starter #17
Would this work for a 2004 as well?
Graves says the 03 and 04 suffer from a low fuel pressure problem and need a "fuel pressure booster" for this mod to work correctly :(
I'm not sure if you could buy just the booster from Graves, if you could find one randomly on the internet, or if it would be easy to make one yourself.
Good luck.
New vid after the slide stops:
-Jamie M.
Boner
So the R6S has higher fuel rail pressure than the 03-04 bikes?
Discussion Starter #19
You got er ;)
The R6S has the same fuel pressure as the 05+ R6's :)
-Jamie M.
Lov'n that blue R6
1 - 20 of 101 Posts
