1 - 7 of 7 Posts
· I Heart My R6!
Hey guys,
I need to change the right foot peg on my 04 because it is damaged from an accident.
I noticed the left side has a cotter pin through the end of the pin that holds the peg in place; however the right side doesn't.
The right side has like a weird washer of some sort or something at the end of the pin and I can't figure out how to take it apart.
Any help to remove it is appreciated!
Thanks
I thought that there was a pin on one side but not the other was really weird too. I'm afraid it is just a rivet on the right and needs to be drilled out. Get a second opinion, but I'm pretty sure that's the only way. Then of course get a bolt of the same diameter to replace the rivet. Sorry I'm not a 100% on this... anyone else?
· Ride it like you stole it
The right side peg you need to cut the rivet off with a dremel or drill it out. Then when you put the new peg on you will need to get a pin with a cotter pin to keep the new peg on.
I also had this problem a while back, the simple solution is to drill it out from the bottom side. It literally takes about 3 minutes if you have a drill with the appropriate size bit to swap the peg out. I recommend some GP Pegs, they come with cotter pin replacements for the shitty idea yamaha had for the rivets and are very comfortable for long rides.
1 - 7 of 7 Posts
