1 - 4 of 4 Posts
I read a write up on how to fix this on another forum. I have a 99 R6, and the throttle play is horrible, so I went ahead and took off everything I needed to access the cables and near the carb, but how the hell do you get at the adjustment on the eariler r6s? Its right behind the frame. I see the write up was on an 03 or higher and its in a dif spot on the older ones. I really dont see how anyone could get their hand or tool in there to access it? any ideas?
It's right by the rh griip. At the top of the cable is a little nut and a longer ex shaped fitting. Loosen the nut and turn the fitting. No need to disassemble...
1 - 4 of 4 Posts
