1 - 19 of 19 Posts
Anyone want to give me a quick rundown of how to install frame sliders for a Yamaha R6 02? If anyone has any tips, suggestions, or links that they can direct me to, i would really appreciate it. thanks all
Mike
well i have an o2 r6 i did the sliders on mine came out pretty clean the only thing is making sure when you cut the holes on yoru fairing they are in the right spot and right size for the circle after you cut them all you gots to do is bolt them babys on .. but i think there some were you dont have to cut your fairings dont know how good they are ... this aint too detailed but should give you an idea of what your looking at ..
Take off your fairings
Unscrew the motor mount on one side
Etiher
-stick the ink part of a magic marker or like a thin sharpie in the hole where the bolt used to be
-unscrew the bolt most of the way and put a piece of something plyable and sticky on the end of it (silly putty, clay, gum, etc)
Put the fairing back on and make sure you get some kind of mark on the inside of it.
This should have given you a good indication of where the hole has to go
take the fairing off
drill a very small hole in the center of whatever you used to mark the spot
put the bolt back in the motor mount hole, not all the way
put the fairing back on
look through the small hole you just made with a flashlight and make sure you are right at the center of the bolt
if you cant tell, stick a small felt tip pen or marker in the hole and mark the bolt
if you hit the center of the bolt, YOU ARE GOOD!!!
if not try again (if you take more than one try it is ok because you are going to bore a large hole out anyway where your multiple small holes are
take off the fairing
now get a hole saw that is VERY slightly larger than the slider.
place the arbor of the hole saw right on the small hole, and carefully drill out your hole **FROM THE OUTSIDE!!**
**it is a good idea to put masking tape across the entire area where the hole is going to go, this will help prevent splintering and any stickers getting messed up**
now put it back together clean up the edge of the hole with a dremmell tool, screw the slider in...(depending on how thick your sliders are you may have to dremmell out part of the lower fairing to get the slider in...I did)
Repeat on the other side....
Congratulations, you are now ready to crash!!!
hahhaha
just kidding
good luck!!!
  • Like
Reactions: patineto
Does anyone have any photos of this? We are trying to install the sliders but after we took the plastics off we couldn't seem to find this bolt you guys are talking about lol. :dunce: Do you have to mod. the fairings?
Well nevermind.... I'm not sure how we missed that haha.
I found pictures on a different thread :)
http://www.r6-forum.com/forums/showthread.php?t=17128
1 - 19 of 19 Posts
