How to replace stock air filter by a BMC (R6 2006)
An easy and short tutorial to remove the stock air filter and replace it by a BMC (not the racing version in my case).
1) Remove the stock air filter
Remove the plastic fairing below the tank and move the tank. Find a solution to have a complete access to the airbox.
The airbox is closed by 9 + 2 screws.
Once the airbox is open, the filter is directly accessible.
Just unscrew the 5 bolts that hold the original filter and you will be ready:
2) Install BMC filter
The BMC filter is composed of two parts: cover + filter
Before to set the filter in the airbox, you need to fix the cover to the filter part, 4 black screws are provided. Ps: use Loctitte in order to keep these parts fixed.
Finally, adjust the filter in the airbox and take care that everything is correctly positionned before to screw the 5 new bolts provided by BMC.
Re-install the covers below the tank.
