1 - 4 of 4 Posts
So as the title says I messed up and really need to fix it haha, I had all the valves out and everything, my box for each valve fell apart. My buddy put the lifters and shims in a bag so now they are all mixed up how can I measure the valve clearance with the head only the valves are all in the correct position but the shims are for sure from the factory as I have some 200 a few 189 a 180 a few 190s please help me
YZFR6... ooodles of HP
Going to need to assemble without shims then check all valves and match up shims if they are still in spec. Chances are, some won't be correct anywhere.
If some aren't correct anywhere is that where I figure put which shim I would need and buy, I know that I can't just buy all 200s and hope they work but then I could buy the ones I need correct?
Yes, typically some can be moved and some have to be purchased. Lash decreases with wear so thinner shims.
  • Like
Reactions: Hoonatic
1 - 4 of 4 Posts
