1 - 2 of 2 Posts
i have a 2001 r6 i pulled the tank to check air filter and put it back together i also pulled the igniton to paint my fork clamp then put it back together now it starts fine idals fine and revs up fine but when i ride it it cuts out really bad under load one ignition wire touched the fork and sparked but the ignition fuse is good can anyone help me i also washed it? did i mabey get something wet i wasnt supposed to?
Discussion Starter #2
well found the problem there is a 3 way rubber hose that connects to the air box and the carbs and thereis a rubber line that runs off the air box well those two lines have tobe plugged together it must create a vacume and when there not connected it will idle fine and rev but if you it under a load ut wont run so if anyone else has this prob that could be the answer
1 - 2 of 2 Posts
