I don't post much, but I am having an issue that I can't seem to fix.
I have an 07 r6, and she will cold start fine. As soon as the engine gets up to 104 degrees, she dies and I can't get her started again unless I twist the throttle. If I let go of the throttle the bike dies. The warmer she gets, the longer she will stay running before rpm's drop out and she dies. I have to get her warmed up to 150+ before she will stay running, but the idle jumps from approx. 1200rmp to less than 500, then jump back up. Sometimes it will jump to 2k rpm and then back down. Last night, I had an issue with the throttle sticking, but I think I have that taken care of.
I have checked throttle cable, TPS, grips (to check if it was snagging anywhere causing throttle to stick open/closed), put seafom in the tank to clean valves. I got my PCIII custom mapped thinking that it would help, and it did not. I asked around a few friends and none of them could tell me why. Hoping maybe someone else has had this problem or may know how to fix it.
