so yeah i just installed my xentec HID kit, it went pretty smooth. but after plugging everything in, after starting the bike the low beam stays on for only a second. and the HIGH beam will come on and stay on when you put the high beams on. any thought? i respliced it, but still same issue. thanks
-RIP
190rwhp......:eek5
Sounds like you either have a bad ballast, or ground for that ballast...get a multimeter and check resistance on the low beam ballast...then check resistance at the relay that turns the low beam on after you press engine start...
creepin in the R6
i had to put a switch on my low beam because it kept burning my ballast..when you start the bike the low beam comes on, so the switch allows the bike to power up and then turn it on and i havent had a problem yet.:toocool:
Discussion Starter #6
Do you have a link for a how to install the switch?
