1 - 5 of 5 Posts
what needs to be taken off? can i access everything by just taking off the mids? or the lowers have to be off also?
Its Only a 600?
all you need to take off is the mid running towards the nose. From there, its just plug and play for the flushmounts. When finishing, you may need to use some Double sided tape or something to keep them from moving. Good luck.
To install the greggs, I needed to take the mid and lowers off. There was no way to be able to put the retaining screw on the backside without removal of the lowers.
On my 08 and my buddies 07 we just had to remove a few of the push pins on the black piece on the back side of the fairing and you can access them from there and you dont need to remove any fairings. Total install took me about 10mins.
What brand are your flushmounts? Did they require wire splicing?
1 - 5 of 5 Posts
