Anyone have a DIY for an intergratd taillight for a 03-05 R6?
Awesome! I hope you can make oneGive me a week or so, and I should. I ordered the damn thing about a month ago, but it's still on backorder. I'll try to make one if it EVER comes in.
Well I wasn't going to attempt to do it myself, figured maybe an electricial guru would figure it out. Heh.only thing u could do is to make the tail flash the red side when turning.... adding in yellow bulbs and all that might be a lil complicated and worth just dropping 100 on the predone tail.
i havent taken the tail apart but i assume that it isnt 'split' in two sections wiring wise [which is what you would need to make only half flash at a time] If you could get in there are cut the circuit board and make each side its own complete circuit you could add in a relay that is triggered by the turn signal lead and the relay would cut off the side when the signal is triggered..... so thats prolly the best way to attempt it yourself.. i dont plan on doing it, bout to order one in a day or two... but crack it open and look at it and see if what i said made sense
I created my own integrated taillight... Take a look at my previous postAnyone know how to do this..but for the R6?
