....Well sort of.I decided i would put take the extra headphones i had stored in my drawer & use them for something.This is all i could think of.I started by cutting a small slot in the back of the helmets padding by the ear.I then inserted the ear piece into the slot so it would end up just behind the cloth & not the behind the foam.I stiched up the slot, ran the wire to the back of the helmet, cut it a little longer than needed.I then cut a small hole in the helmets rubber gasket that run along the bottom at the back.I bought a small 3.5mm jack with a threaded end.Inserted the jack thru the hole & installed/tightend the supplied nut.I also purchased a cable with male plugs at each end.This way i can plug the ends into my Ipod & jack.In real life ill run the cable under my shirt though.Any questions/comments....fire away.
