Jus R6'n along
Ok fellas. Ive run into a situation. I bought a wiring harness for my 02 r6 and i put it on and everything hooked up except the taillight (connector is different) the computer connector is different (the unit has 3 vertical slots and the connector does not). They said it was for an 02 r6. Was there sum different computers and or harnesses associated with this yr model? I checked other years and even checked the thundercats and theyre totally different units. They evn connect different.
I said biiiiiiiitch.....
Hard to tell from the pictures, but will it not fit? Looks like they are both 8x2 pins. Do the wire colours match between the connectors?
Jus R6'n along
Ok fellas I figured it out. The yellow thing inside of the connector pops out and just so happens it was still stuck in the ecu from the other harness. Thanks man for your help.
