1 - 2 of 2 Posts
i have just orderd a K&N + dynojet kit for my 2000 R6. I assume the K&N wont be too hard to fit but does any1 know if the dynojet kit is hard to install? also does the bike need to put on the rolling road? or do i need to do nething else b4 i attempt to fit these 2? cheers for your help ppl :)
I have a 2002 r6 and I jetted my carbs about 5 months ago. Actually, it's pretty difficult compared to other minor bolt on's. If you are mechanically inclinced than shouldn't be that hard but if you're not much of a mechanic I would suggest you take it to someone who knows what they're doing. After installing the jets on your carb, you will also need to synchronize your carbs then retun them, since they won't be in n'sync off the bat. You will need some long allen wrenches, but as far as I can remember, basic tools should do the trick.
1 - 2 of 2 Posts
