1 - 7 of 7 Posts
Hey guys after installing an after market toce slip-on, my bike kinda rides stiffer and wobbly at low speeds. does that have anything to do with me not re-installing the servo motor back? does that control stability? i used a exup eliminator. first day riding it after install so, do i just have to get use to the ride or is there really an issue?
-Thanks
What year R6? If you eliminated the cat and stock muffler than you took off a lot of weight and replaced it with a pipe that is fairly un-restrictive; I don't think their pipes have much if any packing material. That could explain why it feels "wobbly" (less weight, easier to flick around) and "stiff" (less weight on the suspension).
it is a 2012 r6, for some reason i was reading around and thought i came across something stating it controlled stability. i will also check my tire pressure as i read that as well. just riding to work this morning and it just kind of felt weird
**and i only took off the muffler left the cat on
1 - 7 of 7 Posts
