hey guys need some help with this. i have installed new LED indicators on the front of my bike (the left side only so far) and they seem to work fine if you just hold the wires together but as soon as you connect them properly it blows the 7.5 fuse under the left cover at the front of the bike. i have no idea why this is happening and any info or ideas would be great!!!!
Prove it!
Polarity possibly? Overloading the circuit?
wires are definatly around the right way. how would it be overloading the circuit. any idea how to fix it?
Deep Thinker
What year is your bike? 08?
On the 08's this is the wiring:
Black = Ground (-)
Red = Running Light (+)
Green/Brown = Blinker (+)
Makes sure you have them hooked up right!
Also, are the signals made for this bike specifically? If they don't already have the proper resistor installed they can draw too much current and blow your fuse.
definately connecting it to the turn signal. it is an 08 model. the place i bought them from said they were from the o8 model might give them a call because thats the only reason i can see they wouldnt be working. thanks for the help ill let you now what happens
