Vendor
Available for pretty much all modern sportbikes.
LighTech Chain Adjusters not only provide a trick look to the rear end of your motorcycle but they’re also a precision instrument for adjusting your motorcycle chain.
LighTech aftermarket motorcycle parts are not yet available on our website. To order a set of LighTech chain adjusters, call Brad at 866.931.6644 ext 810. You can also email us, send those to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away!
A straight, properly tensioned chain will last longer saving you money in the long run. What sets LighTech chain adjusters apart from other brands on the market today is their click detent adjustment scheme which is akin to that of suspension adjustment knobs. A scale is laser-etched on the unit in a high-contrast manner, making chain adjustment quick and easy, even in low light.
In this way, you can count clicks audibly and verify adjustment so you can be confident you’re doing things right. As an added bonus, you won’t have to deal with the OEM chain adjuster blocks falling out of place every time you go to swap out tires.
And, these chain adjuster blocks are manufactured to tight tolerances which removes axle slop in the rear, further enhancing precision chain adjustment.
These are available in gold, black, red, and blue.
