1 - 20 of 37 Posts
The track is crack.
Does anybody have any advice for loading 2 bikes into the back of a pickup truck?
My friend and I each have an R6 and are headed to NJMP with Team ProMotion this weekend. We rented the largest pickup that Enterprise has. We measured everything, and the bikes will fit in the bed. Also, I previously had posted on here and other members advised me that they will fit as long as they face opposite directions.
I am trying to determine the best/easiest way to load them. Back one in first, then the other one in forward, or the other way around? Left side bike faces forward, right side faces forward? Anyone with experience that can help me out with some tips would be greatly appreciated. Thanks.
Sherman Connoisseur
Drain the tank and lift them up. Muscle baby!
Lol all joking aside ramps and couple buddys should make it easier to push it up
Sent from my SPH-D700 using Motorcycle App
The track is crack.
Discussion Starter #3
I have a couple ramps, and I'm hoping a couple friends who are free.
Also any tips on tying them down so they don't bang into each other. There are 4 hooks in the truck and we have 8 tie downs. Was going to put some bubble wrap on anything close.
i fit 2 in mine, both facing forward, all the time. just have to feed the "inside tie-down" through the front wheel of the adjacent bike.
HOWEVER, this is a pita... and as a solution to this pain, i drilled my bed, and added two additional tie-down mounting points in the middle of the bed. :D
Alright, me and my friend, another forum member did this. Very simple to do. Load the bikes one at a time. So for example, youlload yours on the left side. (if you have canyon dancers, itll be easier.) if not, your gonna tie it down through the your forks. Kinda hard to explain.
But load your bike first say on the left side. Try to get it as much as to the left as possible, just to prevent rubbing from the other bike, and itll be easier when loading up the other one as well, more clearance in the middle. Tie dowb the left side of your bike first, do it pretty decent, then leave a SOME slackk to let it lean to the right. So it will be able to be held up by itself. Then load the other bike up and do the same, but opposite. Your gonna have your bikes right side tie down run through the front of your friends bike's tire. Then same for his through your front tires. That's it!!
If you can load bikes by yourself, then one person can sit on the bike to hold it up if you dont want it leaning. Just be careful if it's leaning to not accidentaly hit it.
Hope that helps.
PM 3rd geer, he built a nice chock for pick up trucks.
For loading it, you will need 2 ramps, have friends help you as it's tricky at first. I prefer to feather the clutch and let the bike go up on it's own instead of having guys push it.
The track is crack.
Discussion Starter #7
Unfortunately I don't have time to build or buy a chock, and I can't bolt anything to the bed since it's a rental.
The consensus seems to be that the bikes can both fit in facing forward. That would be much easier than trying to back one up a ramp. However, just looking at 2 bikes next to each other this seems like there might be some pieces that could get a little too close for comfort. I'll take your word for it though and give it a shot. Maybe I'll try to document it with pics and post a How To thread for future dummies like me.
Thanks.
Thanks.
Without anything holding your front wheel in place(chock) you can have it turn a bit and might be bad. Not sure how stable it would be.
What Walt built was done in 2 hours.
2008 R6
OK, so this is what you wanna do buddy. I was/am in your same situation until I buy a truck within the next week or two. I got the idea from Anthony (chief) and then John (jmejiaa) helped me build it. It's really easy to build.
You buy two chocks at Harbor Freight ($20 a piece I think), a bunch of bolts and washers from home depot, and some 1"x10" wood, and some 1"x4" wood. All together this cost me about $60-$70.
The idea here is that with a rental there are only 4 tie downs. This means you can only truly tie down one bike properly! So since it's a rental and you can't do what Agg suggested above, what I built was a way to add 2 more tie downs without f-cking with the truck. This way the two bikes line up perfectly next to each other.
To tie them down, you need to also buy Canyon Dancers from a bike shop or online (cost me $25 a piece I think), and some tie downs from home depot ($15 for 4).
Just copy this same thing I built below. I think I only made mine 4 feet wide because I would rather not have any issues where the wheels come up in the bed of the truck depending on which type of truck I got.
edit - You'll notice I put one chock ahead of the other. This was intentional. This is so the hand grips aren't bumping in to each other and have room to go down to the tie down.
2 hours to build!
2 hours to build!
great build sir..how far apart was the two chock?
edir: what are those two O-rings thingy in the front/middle for?
2008 R6
I dont' know how close they are. I just put two bikes up against it so that they made room, and marked it. The two "O" rings are for two tie downs. They inside grip tie down goes straight to each of those. Then the outside grip tie downs for each bike goes straight to the corner of the truck that's closest to it.
that's a GREAT non-permanent solution. props man. who knew you had design hair in ya. ;)
i just mounted a couple d-loops to the bed with a 1/2" aluminum plate as a backer on the bottom side. same concept - no chocks.
The track is crack.
Discussion Starter #13
Looks awesome. I should have posted this sooner. Unfortunately, even if I had 2 hours between now and when we leave (which i don't) I won't have access to the truck til Friday evening, so would not know how wide it should be. Definitely going to build this for next time though.
Thank you VERY much, 3rd.
2008 R6
Dude....I didn't have this prior to renting any truck either. I went with 4ft because that's pretty much average. I didn't want mine to be as wide as any trucks....not necessary.
Without something like this, there's no way you're going to tie down 2 bikes man. :fact You wont have enough tie down points on the truck to do it man. Trust me....make the time!
The front wheel stays put with no chocks?
Sent from my Nexus One using Motorcycle App
thats messed up because i was suppose to ride thunderbolt on Sunday with motorcycle excitement, and just last night i get an email saying njmp canceled us out to let you guys on.
The track is crack.
Discussion Starter #20
3rd you convinced me. It's going to be a huge PITA with running around the next 2 days, but I'm going to put together the same setup you made. I'll post some pics next week. Thanks again.
1 - 20 of 37 Posts
