I have a Yamaha 2009 R6 I recently bought it has a power commander V. When I bought it the guy didn't know what he was doing and some of the cylinders weren't firing so I then took off the seat and noticed that the battery connection where the Power Commander connects as well was loose so I tightened it and then all cylinders was firing and my bike was fast as hell then a month later as I was riding on the freeway and came to a stop and then started to drive again the power wasn't as powerful and my pipe sounded weird I have a two brothers exhaust system not a slip on full exhaust. I can't explain the sound of my exhaust but the best thing I can say to give you an idea is it sounds like a weed wacker. I checked all coils and did primary and secondary resistance test and all the coils are good I checked the spark plugs and the spark plugs aren't wet with gasoline they're good. I did not check if they were sparking but I did the water test and all 4 cylinders are firing. Can somebody help me with an idea of what is going on. Also there is no check engine light on was thinking to run a diagnostic test but I don't see the needs to do that because the check engine light is not on. If someone can give me some ideas what I can do or what my problem is that would be great thank you so much.
