Hi all, I have a 2005 R6 5sl that just doesn't sound smooth in the low rpm's.
It initially had a rough idle and would sometimes die on me at the lights. I had the blown rectifier plug which I have now replaced with beefier cables which has stopped the bike dying, and have changed the spark plugs and ignition coils with new ones which have solved the rough idle, I just have this choppy exhaust note that smoothens out and disappears at above around 5k rpm's.
Here's a video, you can hear it towards the end.
05 Yamaha R6 choppy exhaust note
Any ideas what could be causing it?
I have tried cleaning the TPS and putting in seafoam / redex / premium fuel but it has not fixed it.
It happens only when opening the throttle ever so slightly when cruising at low rpm's
