1 - 2 of 2 Posts
Hello all just looking at getting an m4 mid pipe and air filter or should I just go full exhaust either way ill def need the powercommander right? And is there any other professional tuning needed or does the commander take care of it all?
Cheers
Living The Dream
deoends if you wanna spend the money or not...i personally dont like the looks of slip on exhaust..dont like the little pipe that sticks out and connect to the actually can...but youll be fine with a mid pipe....and a pcv should be good, you might need to try multiple maps and see which one works best for you...i had to run through several maps when i had my full leo to see which one worked best....if you want the biggest bang for your buck i suggest getting your ecu map reflashed..get with chiefsmokedawg on here he had a button of knowledge to share with you and guide you in the right directions.
1 - 2 of 2 Posts
