M4 Slip-On???
1010 Views 8 Replies 8 Participants Last post by  Noleman
Just bought an M4 slip-on, $205 shipped!!! I thought the price was killer. Does anyone have one?? How are they?? Its the black one going on my 07 Candy Red R6, so it should look real nice.
1 - 9 of 9 Posts
I have one on my 07 r6 as well with a y pipe and it so sounds awsome and crazy loud
Cool, thanks, cant wait to install mine!!
i have an M4 s/o with mj's header and it is so loud its retarded. Im currenlty in the market to find something that isnt obnoxiuosly loud like the M4 is.
I've got a high mount carbon M4 on my 03. pretty conservative sounding and I love it
ordered a m4 slip-on for mine from motomummy, for an 06 though. Going to have to cut the little bracket and probably have it expanded a bit to fit.
Probably going to be retarded loud, seeing as how the 05's don't have a cat like 06+ do.
Yeah I got the full exhaust from M4 on my 07 candy. Its loud ass hell love the tone of it not a loud screech until throttle is opened up. :D
Congrats on your pipe.
I'll give you a little help with the install because the directions tell you the wrong thing. When taking the stock can off you have to disconnect the ex-up valve cables. The directions tell you to just tuck them away. I think that is stupid. So, what you are gonna want to do after you take the stock pipe off, you need to remove the ex-up valve motor. It is infront of the rear shock. It is only two bolts. Unplug the connector, and remove the box. Disconnect the cables from the box and re-install it the same way you un-installed it. Make sure you reconnect the electrical because you will get an error code/check engine light if you dont. Now you don't have any cable hanging down. Good luck and congrats again.
+1. I would reccomend our systems to anyone.
1 - 9 of 9 Posts
