1 - 13 of 13 Posts
Now that I'm track only, I'm curious how the maintenance schedule goes....currently I'm at 4000 miles ish. Only thing I done is air filter change and oil changes.
I plan on doing the spark plugs at the one year mark of my bike then do the fork oil at the end of the season next year.
So far I currently have three trackday under the r6. I change my oil after every two trackday with rotella.
Curious what everyone else is doing for the maintenance schedule since a track only bike is a lil different when it come to maintenance intervals with mileage.
-- full suspension service at start/end of season and halfway through season
-- oil change before every weekend on track, filter every other
-- plugs and pivot points (swingarm, steering head) lube every off season, air filter inspection (one of the things i need to upkeep better)
-- steering damper refresh every other season
-- chain clean and lube morning of every day on track
-- clean/lube axles every race/track weekend
-- wash after every event
-- valve clearance check every off season
-- brake fluid every other event
iRun
I don't race, I'm just a track junkie.. Middle of the pack intermediate group, and I do this:
Lube chain at the end of every track day.
new oil/filter every 4-5 dry days
Suspension refresh at the end of every season.
Plugs.... maybe every other season.
iRun
My bike is my therapist
It really wears out brake fluid that quickly when you ride on the track? Currently change it about once a year street riding..
iRun
No... But it's the same with people changing synthetic oil after every track weekend. Some people just wanna throw money at a thing, so you've just gotta let 'em.
Brake fluid flushes every few days too.
ah yes forgot about that. i do it, just didn't write it down.
lever feel is no longer consistent and gets mushy after a few rounds at the track.
i do it as a pre race maintenance ritual, that way i know when i unload my bike at the track my brakes are going to be solid every time.
Parts Pimp
:fact
I luv me a fresh bleed and flush
crashing aint so bad
If your just a track day person you should be fine with a more relaxed regimen.
Oil change every 4 track days, or 4 months, which ever comes first.
Change the brake fluid once a year.
New chain once a year. Be sure to do a cleaning and lube job before every track day.
You can do the suspension refurbish once a year, or every two years even. It is best to do it once a year.
The swing arm & steering head bearing should be done once a year, but can honestly go for two, or more without issue. Again it is best to do it once a year though.
Coolant flush and change once a year. This is a must do.
Clean the air filter with every oil change.
Change the plugs once a year, or as needed. They are truly good for 8,000 miles. You won't get that many in a year on the track only.
I go through a check list before every track day that goes over all the little things:
Check important bolts before every track day if they are not safety wired. I check the throttle cable to be sure it's not fraying or starting to split.
I check wheel bearings for play and and do a quick once over on any thing that has been changed!
I always start the bike to be sure that my temp warning light comes on ( I don't use fans and placed an LED light in their place ) , or the fans work when they are supposed to.
I listen closely to the engine while it's getting up to temp for any possible issues.
While I have the tank up I do a check of all the rubber hoses for cracks.
I always check the oil, brakes, water level, clutch play, steering damper function, clip on bolts and bars, as well as fuel level.
Anytime the air filter is checked, check the throttle body sync and adjust as needed.
If I'm really working the brakes, I get no more than 2 days before needing to bleed the brakes to keep the lever up.
Make good choices.
Yup. Most track riders change their oil too frequently. They will say the $30 for a few quarts of high end oil is cheaper than buying a new motor; that it's cheap insurance. And maybe they are right, no sense in trying to talk them out of it.
I run Amsoil. I do about 1 to 2 track weekends (2-4 days) per month during the summer. I've had one Amsoil rep tell me I could go all season on the same fill, and another said a few months, easy. I normally change it at the beginning of the season, then once more in the middle.
If an R6 motor fails (especially a built motor) it's probably because the oil level was low or the bike was cold, not because the oil was old.
1 - 13 of 13 Posts
