1 - 2 of 2 Posts
I took my bike in to check the stator problem(coupler on rectifier is bad). Where can I get another coupler? I'm pretty sure it's just the plug coming from the rectifier.
They said the chain and sprocket are worn, but the sprocket teeth look very good to me and the previous owner thought they were full of it as well. With the chain/sprocket they said the master clip was backwards? I'm not really sure what that means, anyone shed some light on that for me?
Last question, Could I replace the brake pads myself? I've read some how to's and it seems pretty straight forward.
Brakes are super simple do. If you have any confidence in your ability, I would attempt them.
As long as the teeth are still symmetrical on the sprocket you're good to go, don't worry about em.
The click on the master link has an open end and a closed end. The closed end should be facing the direction of travel. So if the master link is on the top of the chain, the closed end should be towards the front of the bike.
1 - 2 of 2 Posts
