1 - 7 of 7 Posts
I ordered fairings from monster fairings and then they (finally) got here the headers are touching and melting both sides. I didn’t have this problem with my old plastics and they are saying that it’s not their fault (I used extra heat shield, it burnt straight through both layers.) I have a Yoshi Alpha T exhaust. Any help is appreciated
Administrator
Were your old fairings OEM or aftermarket? Do you have a full exhaust? That could change the positioning of the headers.
Drill holes and add stand-offs. The OEM engineered "stand off" for the exhaust pipe on my 2nd-Gen bike uses a (high-temp) silicon isolator.
Should be able to compare replacement to original, see the problem and compensate accordingly though.
Hardware stores will have the standoffs and fasteners. Might have something that is made from high-temp silicon but if not, can make something by purchasing a small tube of gasket maker from the auto parts store.
2 wheels > 4 wheels
Have you tried some heat shielding, like insulating tape? Or grip tape you'd use on baseball bats...?
Most aftermarket fairings aren't as high a quality as OEM unfortunately, and hence the higher price. IIRC, most aftermarkets are made of fiber-reinforced resins, not some high quality ABS.
1 - 7 of 7 Posts
