Anyone have their blinkers die?
The whole left side is not working, and the right side is intermittently working.
I dont see any loose wires....
The back are aftermarket but conventional. the front are LED, but I don't use a rectifier (so they blink fast).
I'm assuming its not a fuse because the right side is working 80% of the time. Everything else n the control is working (horn, highbeam)
Brake lights are working...
Any ideas?
Any ideas?
I have the same problem, my blinkers don't work, and only sometimes does the indicator work....bump for a response for both of us. :YEA
I did double check and the fuse is good.
I'm thinking:
a) maybe the control itself? it's the whole side, not just 1.
b) I had the airbox up, and the heat shield under it in a failed attempt to change my plugs. I had undone all the connections over the shield. Maybe one of those connections loosened up?
Taking the airbox off is one of the last things I want to do though, such a pain in the a$$ !
