1 - 19 of 19 Posts
i just bought my r6 and put it up on a wheel stand to change the fluids and change spark plugs put it in gear and watched wheel spin the chain is real sloppy. the guy before me put Vortex Racing 520 Chain Conversion Kit with RK-XSO Chain. is there a way to tell if i need to take out a link or can i just bring the back wheel back to tighten it up any help will be great thanks
Habitual Linestepper
post a pic, bring the wheel back,if you have room
i know i have the room to bring it back some didnt know if theres a limit to how much i can bring it back before its unsafe. i will get a pic .is it hard to move the wheel back ive never done it
Stunt Rider
Just adjust the wheel back for less slack.
Loosen the axle nut. use a 10mm and bring it back. Tighten axle nut, done.
Live Love burn Die.
my stock chain bounced a little when rotated up on the stand too.. i just thought it was the chain getting torqued and untorqued since there is literally no load on the transmission
by sloppy.. i assume you mean it bounces around... but then again "assume" makes an ass of u and me! but for real, sorry if thats not what your referring to
no my buddy has a cbr 600 and his chain isnt lose like mine i think its pretty bad looks like it could jump off the sprocket .im sure you have to bring back both sides even so wheel doesnt get cocked correct
Stunt Rider
:lmao He said "Cocked"
Waiting for remission...
Yes, put bike on stand, loosen axle nut, rotate adjusters on both sides until chain is tightened to proper spec, retighten axle nut. It's really quite simple. You can google how tight it should be if you are unsure.
Discussion Starter · #16 ·
thanks guys i watched it on youtube it is easy like anything else in life once you do it once its easy i changed plugs,coolant and oil was real easy from the help of the search button on this site thanks guys
Stunt Rider
I don't even use a rear stand when I adjust my chain.
I'm probably suppose to use the stand but, fcuk it, I'm lazy.
Hola Amigos!
I think I'm losing it
It's like someone posted this website on every billboard/telephone pole.. 'IF YOU HAVE A BIKE GO TO R6.FORUM.COM' :nono fcuking noobs, learn the search button. K thx bai :wave
1 - 19 of 19 Posts
