1 - 7 of 7 Posts
Anyone up for giving me these dimensions?
I also need the overall width of the drive.
Thank you!!!
You are the man!
I have a Roadstar bobber and if you didnt know its left side belt drive. I am making it right side chain.
If you look up the MT-01 it is the same motor as a roadstar but right side chain drive (Its a euro bike) They removed the transfer case and shot a chain straight back. The MT-01 cush drive looks identical to the R6 / R1 and kind of similar to the Roadstar so i am hoping i can purchase one from an R6 / R1 and modify it a bit to make my stock pulley driven wheel a sprocket driven wheel. I realize i have to change out bearings and possibly do some machining and throw in some spacers but i will be a step ahead with the sprocket bolt pattern already set up in the new cush drive. R6 cush drives are cheaper than purchasing a new wheel.
A closer look...
The part numbers are in fact different but i am hoping they are close enough for me to work with it.
R6 Dampers
Road Star Dampers
R6 Cush Drive
Road Star Cush Drive
1 - 7 of 7 Posts
