Mario J's Apple Juice
Hey guys, just a quick question as I'm finishing up my projector install. Kit is from Krypton bulbs, tried to pm him but I guess he's not on.
He says:
The pink wire is the high beam positive wire, the White wire is the low beam positive wire, and the blue wire is a ground.
So do I need to splice this wire or do I plug it in somewhere?
Thanks
MACGYVER 05 R6 NJ
He says:
Thanks
If the other end of the wires goto the ballest or bulbs then you have to splice your stock wires to that connector.
Pigs can fly!
So.. your bike takes H7 bulbs if I'm not mistaken.
One side is lowbeam, the other side is highbeam.
The connector you pictured is for an H4 high/low harness.
Last I checked, H7 connects using spade connectors.
From what I can assume, you need to connect the lowbeam as normal, and connect the highbeam's positive to the highbeam lead of that h4 connection.
The projectors just move the highbeam cutoff away when the highbeam signal is applied.
Try connecting the lowbeam's connectors first to make sure that works. Then add the highbeam toggle after.
