New 2000 R6 rider
700 Views 3 Replies 3 Participants Last post by  felsbadman
Hi all,
I've purchased a 2000 R6 around a year ago and have been trying to fix it.
The bike has been open for a few months and I can't find where this part connects.
See red circle on the drawing, itemnr 36. The third way is going nowhere.
Can you help me out?
Thanks a lot and best wishes for 2022!
Organism Handwriting Font Line Slope
1 - 4 of 4 Posts
Thats a weird one- its left loose. Like that on my '99 also... perhaps its a fitting to support some kind of test in the factory and plugged afterwards.
Thanks for the feedback!
After some further investigating I found following clip on youtube:
It some kind of vent hose, I will leave it open for now.
That fitting is connected to the hoses that go into the top of the float bowls of the carburetor. Basically, at higher speeds, the ram air system allows that line to pressurize the float bowls for more fuel pressure. The T fitting that is in question is there to allow the carbs to vent any excess overflow of fuel from the float bowl instead of back into the airbox. It should stay unplugged as you see it, and don’t freak out if you ever see a tiny bit of fuel dripping out of it, only if it is for some reason spewing fuel should you be concerned(most likely a stuck float or faulty seal on a float needle allowing fuel to continuously load into the carb.) hope this helps some!
  • Like
Reactions: 1
1 - 4 of 4 Posts
