Hey guys & gals - I'm new here, so thanks for having me! Looks like a great forum! I hate to make my first post a cry for help, but I really need some right now.
I'm working on getting a used '99 R6 working. I was having all kinds of fuel issues, so I disassembled the carbs, and found that a dynojet kit had apparently been installed, only incorrectly. Upon pulling the CV diaphrams, I found one needle was missing both shims (dynojet calls for 2 shims on each needle), another had them just floating loose in the diaphram assembly, which had somehow locked up the slide.
This is all no big deal... I can fix all this. But I'm a little confused over one thing. After seeing the mess that was made of those carbs, I first looked at a diagram of the carbs on RoyAyers, noting that they show the stock needle assembly containing the needle, a washer, and a spring (not the diaphram spring, but a spring between the head of the needle and the clip that secures the needle into the diaphram assembly). I then contacted dynojet, and asked them if the spring & washer were supposed to have been retained in their installation. They said yes. Granted, none of these parts exist on the bike I'm working on... just the dynojet needle, the e-ring, and 2 shim washers above the ring (on the carbs that had 'em).
HERE'S WHERE I REALLY GET CONFUSED...
I look in the factory service manual, and their diagrams of the carbs don't show or mention either the washer, nor the spring, that exist in the microfische on Ron Ayers :roll:
HELP ME!!!!!!!!
Could someone with this model bike please tell me whether this small spring and washer are present on stock carbs? And if so, what are their dimensions and placement on the needle. And for those of you that have installed dynojet kits, did you retain these parts (if they existed in the first place)?
THANK YOU!!!!!!!!!!!!!!!!!
HELP ME!!!!!!!!
