1 - 20 of 20 Posts
Hey Guys,
I really need some help on this one. A few weeks ago my bike was vandalized and/or attempted to be stolen. They cut the wires from the key ignition side, unplugged the 2 connectors under the left black plastic and took the wires. I went to the local Yamaha dealer were i purchased a new, OEM ignition. After install, i turned the key on, everything lights up, fuel pump kicks on, dash lights, horn, blinker - but the bike doesn't even try to start. I replaced the starter relay as well and it didn't make a difference. I took the kill switch assembly apart on the bars to check the start button - Ohm reading proved it was making and breaking. I have checked the bike over and cant seem to find any others wire cut or sabotage. Battery is reading 12.34VDC.
I did notice that the mileage was reset to "0.0" on the gauge cluster. Any insight on this would be greatly appreciated!
nova r6
Check for any history or current codes in diag mode? Also is the kickstand and neutral switch working, confirm in diag mode. Lastly there is a saftey switch relay under the seat number 28 in the diagram
In the service manual electrical chapter there is a section on the electric starting system. It explains the relay and ways to test the system
Discussion Starter #5
tdoss1980,
I just read about the diag mode last night which i had no idea about. My manual doesn't seem to mention anything about it. I've read on this fourm to get into diah62 and hit the kill switch on and off to reset. I will try that later tonight. I will look through my manual again, but i did not see any information on how to test the electrical. Everything reverts to "send bike to dealer". Thank you for some avenues to check out!
nova r6
No problem, do you have the factory service manual?
If not you can download it here:
Section 8-7 is the electric starting system section
Section 8-35 goes thru all the code numbers and meanings
Section 8-40 talks about diagnostic mode
Dont go to DIAG 62 without first seeing DIAG 61 to see what codes are there. Just remember that the bike stores ALL codes in history until they are erased but still worth jotting down incase. After that clear the codes and try again and if any codes come back that will give you an idea where to go.
Discussion Starter #7
I do have the manual, but i didn't see anything about getting into the diag. My manual goes from 8-4 right to 9-1. Sounds like for some reason, mine skips some pages? I wish i had read your post before i cleared the codes - 92 did have 1 and i cleared it. Still no luck though. I went back in after turning off the bike and it stayed "0". I did notice that when in neutral, there is no indication light on the gauge cluster like there usually is. I ordered one of those relays you showed me - i can't imagine there would be much more left other than the ECU. The neutral, kick stand and clutch are all just switches, how would any of those go bad. It aggravating that with all the fuses and safeties, not one thing seemed to catch the short to ground, or whatever they did when the ignition was cut. Thanks for sending those manuals, I'll print out the 2008 one as it should be the same.
nova r6
If your kickstand is down and neutral light is not coming on the bike does not know that the bike is actually in neutral. Have you tried starting it with the kickstand up and the clutch pulled in? Try this even though the bike is really in neutral and see what happens. The neutral switch is on the back of the motor by the shock and is a simple ground/no ground switch. When in neutral the switch grounds out making the light come on and any gear the ground goes away cutting the light off. Could even be a loose connection back there
Discussion Starter #9
Yeah, i have tried every variant of trying to start the bike, and i get the same result. If that relay box you showed me controls all the safety switches, there is a good chance something in there got fried.
Discussion Starter #11
Once i get the new relay, i'll give it a try and report back. If it doesn't work, i'll just have to bring it to a dealer. Thanks again for all your help, tdoss1980. I'll update on what comes of the new relay!
Discussion Starter #12
*Update
I put the new relay in and doesn't make a difference. :( Thats just about everything besides the ECU and gauge cluster.
I'm at a loss. I hope the dealer can figure it out.
It's odd that your odometer would reset to zero. Are you sure it wasn't the trip meter? I've had my cluster completely out and it never reset to zero.
Check your ignition and backup (meter) fuses. Your neutral light switch grounds the LED that's in your dash cluster. The cluster gets its power via the wire harness that plugs in on maybe the right side fairing of the bike; if not right, then left. Make sure nothing was damaged there. Go over all of you harness and make sure they're plugged in, with no evidence of tamper or damage.
Discussion Starter #16
Intuit, yes I meant the trip, not the whole odometer. My mistake. I don’t see any other wires cut or tampered with. There is a high pitched , constant “ring” when I turn the ignition on coming from the the center of the bike somewhere. I don’t recall it before, or at least as loud. They cut the ignition wires, then unplugged them under the left fairing. Doesn’t seem they had tools - everything was pulled and cut with a knife. I will likely go through it again before I send it in. I just get aggravated real quick given the whole situation.
It's normal for the trip meter to be reset with power loss. Presumably you disconnected the battery in the course of repairing the wires they cut. If the trip meter and clock keeps being reset then the meter/backup fuse is blown, or it's connection to the cluster via red/green wire is compromised. THe other posibility is that the dash button is stuck. This happened to me with an aftermarket replacement case for the dash cluster.
Some electronic components such as capacitors and voltage regulators make the noise. It may be normal and was never noticed before. 12.3v is a little low. Do you see a drop in battery voltage when you attempt to crank? If you see a dramatic drop, then it may be attempting to crank after all.
Discussion Starter #18
I didn’t look too close at the clock times as I have been keeping the battery unhooked until I figure this out. Where is that button? I have the 2 buttons on the side for menu purposes.
The ring could have very well been there before but it was just something I now noticed. I don’t see any drop in voltage when I try to start it.
Given what you've described... that it worked... they cut the ignition wires... you replaced the ignition, now it doesn't work... logically we should start there.
Diagnosing this involves testing each wire for the proper voltage, given the current expected state of the circuit. There won't be a quick/simple answer.
Use a straight-in to pierce wire insulation and get your readings that way. Be sure not to stab yourself.
What do we know at this point?
  • lighting/signal circuit is completely functional -- brown/blue has a strong-enough 12v
  • Do you have 12v at the kill switch? - if yes, this would imply that your ignition fuse is still intact
  • Do you have STRONG 12v at the clutch switch? - if yes, then the ignition is putting 12v on the blue/yellow wire
  • Blue/Black wire off the ignition feeds 12v to the ECU. Do you have a STRONG 12v at the ECU?
The fact that there isn't a neutral light on the cluster is a clue, and will be the next area of focus.
Discussion Starter #20
I will do these tests this weekend and see. I assume so given how everything else works. Fuel pump comes on no problem by switching the kill switch on. The start button makes contact (ohm resistance)
1 - 20 of 20 Posts
