So I just bought it yesterday, first bike and i love it
but the check engine light turns on and the guy who sold it said he went to the dealership and said they told him, it is because its been sitting and needs an oil change. is any of that true?
And i have an issue with the throttle not responding sometimes, I have to turn it off then on to work again. Happened 3-4 times yesterday and none today so far.
Mr. HER6
One of them is full of BS. The computer has no idea when you need an oil change. If the CEL is on then something is wrong. What is the code number that is displayed? I'm guessing it's related to your flaky throttle.
nova r6
OK youre in the right area but wrong number. You need to do the same thing to get where you did and after that use the reset button to get to d61
Fault codes 11-60
• (If more than one code number is detected, the display changes every two
seconds to show all the detected code numbers.
When all code numbers are shown, the display repeats.)
These numbers will tell you which code it is and where to start.
If you dont have a service manual you can download it here
http://www.r6messagenet.com/forums/pdf/2007_R6_Service.pdf
