1 - 10 of 10 Posts
never changed oil on a bike b4, how do i know if the oil is low or needs to be changed? is there a dipstick?
There is on the 03-04. Not sure about the 99-02.
Directly under the oil filler cap, on the right side, there is a black plastic knob.
That's your dipstick.
Bacon is extra!
make sure the bike is straight up and down though. If it's on the side stand your reading will be messed up.
Out of the topic but how accuate is the hondas visible oil level?
Not a dummy, just OBVIOUSLY new to riding!!! hahahaha-It's all good. We all had to learn at some point. :stupic
looking for more curves
damn straight! At least your worried about the things that you should be worried about!!
yup same as 99-02 :cheers
yea, make sure the byke is in the (straight) upright position before pulling the dipstick. Also the proper method for checking the level on the dipstick is to first unscrew it, clear it off, then put the stick in *WITHOUT* threading it in at all, checking level. That will give you an accurate level reading.
1 - 10 of 10 Posts
