Viva capitalism...
I am considering purchasing a slip-on exhaust. However, I was informed that I would also need to pick-up a Power Commander. I don't believe that, but I want to double check. I would really only need the Power Commander if I installed a full system exhaust, ya? But if it's just a slip-on you don't need the PC do you?
Thanks in advance!:menace
wants to drag knee
there are alot of people that run a slip on without a power commander, as far as i know you should be ok with a slip on and no PC. however if you put on full exhaust it would be advised to get one
your not gonna benefit anything with it except good sound, your bike will actually perform better stock than with just a pipe and no pc. and your gonna be running a little bit lean.
