1 - 2 of 2 Posts
Vendor
A steering damper is one of the most important upgrades you can purchase for your motorcycle. Not only is it required for racing and highly recommend for most trackday organizations, it can help keep your front wheel in check during any "spirited" riding you may have on your local streets.
Not yet listed on the website, if you would like to place an order or have any questions give Brad a call at 866.931.6644 ext. 810. Is email more convenient? Send us a message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
A steering damper helps keep the front end in line preventing the dreaded "tank slappers." Available from Riders Discount are the linear piston style Ohlins steering dampers that are used by the top motorcycle racing teams in the world.
Even if your motorcycle comes equipped with a damper from the factory, they aren't as precise or as adjustable as an aftermarket damper like the Ohlins pictured here. Included with the kits that replace a factory unit is a resistor to eliminate any warning lights that may appear when you remove the old damper.
Precision machinery on any included brackets.
The adjustment knob allows you to fine tune the amount of resistance and can be easily used with a glove on.
Give us a call to place your order today!
1 - 2 of 2 Posts
