1 - 11 of 11 Posts
Cant get my oil filter out on my 04 R6, tried those wrenches but doesnt budge. Any good tips? Thanks.
Intermediate Knee Dragger
Just get a large set of channel locks. Since you're not reusing the filter, who cares what it looks like when you get it out of there?
i bought one of those oil filter cap wrench but it kept on slipping so i put rubber band around the filter to give it a little more grip and slide the cap over top. that should give enough friction to open up the filer. other thing i did was cut a piece of cardboard and place it between the filter and the cap to make it tight enough for the cap not to slip.
Phi Phi K A
screwdriver
+1
Get a long screwdriver and bang that bitch right threw the filter and use the driver as a handle and it will come right off. It gets a little messy though so make sure the oil is drained first(duh?) and make sure you have an drain can underneath.
I sold my R6
+1
Screwdriver works but be carefull. If you rip it in half it's a pain in the *ss to get off. I'd just get the cap or a strap wrench.
Phi Phi K A
Tru dat!!
I'll try the strap wrench first and if I still cant do it i'll probably use the screwdriver. Thanks a lot guys.
1 - 11 of 11 Posts
