2005 r6 Oil light stays on when oil is full. And yea I measure it with dips stick not threaded in so it’s reading correctly. I Uninstalled the oil level sensor. Tested it in the upright position. And it read between 114 and 126 ohm. When I flip it upside down it reads between 484 and 536. Now that is totally opposite of what is says in the Manuel. Now if the I have it right side up with the wiring at the bottom the way it is installed and I pull the float up it reads correctly. So I am I testing it like it had full oil or like it sits with no oil in it. Kinda confusing. I have another sensor and it tests the same. Can someone give some clarity. Here’s pics from the Manuel
