Status
Not open for further replies.
1 - 20 of 50 Posts
The ALL NEW Annitori RL "Gen 2" Quickshifter!
The BEST just got better!
Everything you know which made the original RL one of the hottest products ever, now even better with these "Gen 2" upgrades:
__________________________________________________
* Processor / Controller body design is "flat" now. We had customers commenting that the round body shape was hard to mount on the many flat surfaces of the motorcycle. This eliminates this concern.
** We have changed the "click key" setup method to a button on the backside of the controller. Many racers, and some of the newest OEM bikes, use unusual ignition setups where "clicking" the key on and off was not easy or useful. With the change of the Gen2 to the button method, virtually every type of motorcycle out there can enter setup mode easily.
*** Lastly, and most importantly, we have upgraded the electronics to the finest we have ever offered. We do this each time we have a release, but this particular time we decided to invest in "a step higher" setup that allows for a more stable electronic platform, including a brand new output section and much faster processing. With these changes we were able to take advantage of the faster processing to tweak our algorithms even further, for the fastest, smoothest and most consistent shifts ever available.
And still ALL of the features that have made the Annitori RL the finest Quickshifter option available:
* 100% Digital Operation - No moving parts or mechanical switches to fail, ever.
* Lifetime Warranty against design malfunction or defect
* STAND ALONE design - No interface issues, no added hassles, never a mis-communication - everything in the RL is self contained operation
* HM's Strain Gauge sensor - Same technology used by MotoGP and World Superbike - nothing is better, period.
* HM's Intelligent Ignition Controller - the "heart" of the design, and what makes every other product pale in comparison
* HM's Digital Signal Processor - complex algorithms compensate hundreds of times per second to manage the strain gauge signals for flawless operation
* UP or DOWN shift pattern operation - the RL operates in either direction; can be changed anytime and as often as you want.
These are just some of the features of the RL Quickshifter to get everyone started. Please let us know if you have any questions, happy to assist and get them sorted for you.
Re: ALL NEW Annitori RL "Gen 2" Quickshifter
We think you need to add more bikes to your stable (maybe a new R-1?) then more RL's..! Good for both of us! :)
:lmao
:cheers
Track=Cocaine
DO WANT! Sooooo bad!
Discussion Starter #7
Everybody please remember that if you are using the stock footrests, you have two different size heim joints and need the conversion rod. You can see what you need on our website here:
http://www.annitorirl.com/producthome.php?make=15&model=105&year=14
Just be sure to look before you order, or contact us [email protected] and we will sort it with you quickly and easily.
Always happy to help, let us know if you have any questions!
Discussion Starter #10
Just received mine today and got halfway through installing it.
One thing I wasn't sure about; do I have to do anything to tell it if it's going up or down?
No, the key is to keep the wires free and able to move with the shifter, while not interfering. "Up or down" does not matter...
Make good choices.
I see, so the orientation of the sensor doesn't matter, it's just always cutting ignition whenever it gets a signal from either direction.
It was like a brain teaser trying to figure out how to thread the shift rod, sensor, three grub screws and two heim joints all together.
Discussion Starter #12
The VERY cool part is that our sensor and shift rods are LEFT and RIGHT hand threads in each end, so you don't have to worry about which end is which. A very unique and special manufacturing process, but one that really makes it easy to get the assembly right!
My R6 Hates Water!!!
Forum discount?
Who is a vendor on the site so I can check ?
Dangerously Irish
Discussion Starter #18
We are 'ol fashion capitalists, so any real vendor, dealer of supplier you like to work with is welcome to call us and place an order for you.
On that note, if we start picking "one" name over another, then every other supplier (and dealer associated with these forums) thinks we are playing favorites and stops doing business with us. So rather then make anyone mad, you the consumers choose who you like to support or work with and they can then place their orders with us for you.
If we can assist you with any product support in any other way, please let us know!
1 - 20 of 50 Posts
Status
