1 - 10 of 10 Posts
depends on what you use. Premixed stuff like Duplicolor Paintshop took me about 2 qts of each stage(primer, base, clear) and then non mixed will be 1 qt of each stage plus activater(which is usually 1 qt if it is a 1:1 mix ratio). I sprayed about 4 coats of each stage!
MMVII R6
:Dhey man my brother just got done painting my bike and to be honest if you are not a experienced body work and painter i would leave the project to a professional, he is a professional and has done a ton of work in cars not bikes and we ran into a bunch of little problems because neither he or i knew anything about plastic in the bike's body, the tank was not a problem cause it is metal but the rest of the fairings have different properties than metal and if you do not choose the thinner for the paint or clear correctly the actual plastic will react funky and start to peel off, also when applying the paint it has to be slow and thin coats, hey if you need more info pm me i have a lot of pics too if you are intersted in see what we did and check out my bike and let me know what you think.
1 - 10 of 10 Posts
